Re: tohatzu 40c missing at half to full trottle run great at idle to half HELP!
"White milky" usually means infused water. That may be your issue. The best plug to run is the NGK BP7HS-10, either resistor type or not, depending on your preference and the local availability. You may want to check compression and have a look at the reeds -- while very durable, you could have a reed stop out of whack, or a slight crack in a reed.
