elkhunter338
- Joined
- Jun 27, 2009
- 818
I am converting from a 21' starcraft (Chieftain) been participating in the starcraft forum. To a Tolman Jumbo, boat building book is Tolman Alaskan Skiffs by Renn Tolman. This is a stitch & amp; glue plywood/fiberglass/marine epoxy boat. Basically a composite boat, light weight, very sea worth. I fish the pacific ocean (Oregon) and wanted a bigger boat, could not find a 25 or 26 foot starcraft to rebuild. So earlier this year I started building a Tolman Jumbo. You can start from a kit or raw materials. I chose the raw material route, Hydrotek marine plywood, versa-lam stringers, doug fir shelves, aero Marine epoxy. Pictures say a 1,000 words so here is the progress so far. If you have questions ask away, this is the first boat I have built, had lots of help from fishyfish friends (tolman boat building forum), of course the Renn Tolman boat building book. https://en.wikipedia.org/wiki/Tolman_Skiff
Many reason to build a boat like this mainly cost savings and light weight (light to tow and requires less hp). A 27' with a 150hp OB will run 30+ mph and get 3.5 mpg.
I off set the transom cutout 30" one side for a kicker and slightly less on the other side, plan to off set the main engine 8" to help make room for the kicker. Others have off set the main with no ill effects that way the kicker and main won't hit each other.
Just glassed the bottom and sides this weekend, adding additional layers of epoxy and ordered paint. Hope to flip in July and start on the cabin/pilothouse/floor.
