Re: Tongue weight vs. trailer weight
No it's not! If you want a decent towing load 10% and as high as 15% is the norm. Some "trailer" manufacturers may recomment 7% but that will be a "minimum" recommendation or starting point and is done for the whimpy tow vehicle frames (or lack of them) and suspensions we have today.
I must have lived a sheltered life then. I've always seen boat trailer manufacturers suggest 10% is the MAXIMUM. What does YOUR trailer owners manual say? The one for my current Caulkins clearly states 7 +- 2%.
Loadrite -
http://www.loadrite.com/pdf/LoadRite-Owners-Manual/OwnerManual0110LR.pdf
For trailers 2000 lbs. and under, the tongue weight is approximately 7% of
the gross weight (GVWR).
For trailers over 2000 lbs., the tongue weight should equal approximately 5% of the
EZ Loader -
http://www.ezloader.com/Manuals/ezloader/custom/Owner's Manual.pdf
Five to ten percent of your trailer’s Gross Vehicle Weight should be supported by the hitch ball, with the tongue level.
Shoreland'r -
http://www.shorelandr.com/pages/pf_trstep3.htm
To determine proper tongue weight, total the package weight (boat with fuel/battery, motor with maximum horsepower, and trailer) and multiply it by 6% on single axles and 5% on tandem axle trailers. ShoreLand'r suggests that tongue weight may be acceptable in a 5-7% range.
Karavan -
http://karavantrailers.com/faq.cfm
It is recommended that 5-10% of the total weight (trailer weight plus the weight of everything loaded on the trailer) be on the tongue. For example, the gross (or total) vehicle weight of the trailer and load is 2,000 pounds. The tongue weight should not be less than 100 pounds and no more than 200 pounds.
Lots of trailers suggest more tongue weight, but generally not small boat trailers. It is usually suggested 10 +- 2% for an open utility trailer, 12 +- 2% for a cargo trailer, 15+- 2% for a travel trailer, and 20+% for a gooseneck or 5th wheel.
With wheels far back on the trailer and no flat front on a boat less tongue weight is required. I have never had any sway towing a boat at 7% while a travel trailer with a 7% tongue weight would be a wreck waiting to happen.
