Chevy 305 small block.... Put heads on, but had an extra bolt that we couldn't find where to go.... There is tons of oil getting in the coolant passages... the bolt is about about 1.5 inches long... could a missing bolt cause TONS of oil to go into the cooling system (heat exchanger).... assuming the head bolts were all torqued correctly? Also, if this bolt is meaningless and has nothing to do with the problem... would a new headgasket not torqued correctly cause so much oil to get in the heat exchanger that it looks like and has the consistancy of mud? I do not think it's a cracked block..... but that missing bolt stumps me. There is no water getting in the oil... Oil is fine... is the only way for oil to get in cooling system through the head?
