Re: Too much oil in gas
Like he said, right now you're about 30:1. It will most likely run just fine, probably unnoticable if you're running fast. Trolling, it might foul up the plugs, but I really doubt it.
Also like he said, you mix double oil during break in - and also if you're testing a oil injection system, you're supposed to put 50:1 in the tanks and then observe the oil tank to see if the oil is being used (which results in double oiling also). I've never heard of people having significant performance problems doing this.
If it were me, I'd just go for a ride and burn off 5 gallons of the rich mixture doing something high speed (meaning not trolling or idling) - cruising, skiing, tubing, etc. Then add 5 gallons of plain gas and you'll be back around 45:1 at which point forget about it. I've used 40:1 and never had any plug fouling, even trolling.
The good news/bad news deal if it were my boat, is good: it would only take about 20 minutes at WOT to burn 5 gallons... bad: it would only take about 20 minutes.... ;-)
