Is it possible to damage something if puller is tightened too much? I made hooks out of 3/8" eyebolts. Transmission fluid, rust buster and other stuff has been put on the bearing case and heated with a small propane torch.
I should have just replaced the seals instead of heating but didn't know better, anyhow the Oring should probably be checked. The heat from a big propane gas tank was used so it got really hot once.
Thanks.
Thanks.
