too smokey? E15RERE
rich79
Hi again,
I just rebuilt the carb on this motor. there is ALOT of white smoke. i am using seafoam in the gas/oil mix. There is a milky exhuast liquid coming out of the back of the motor as well (pictured). is this normal? compression is 120 on both cylinders.
these pitures were taken at about 2000 RPM
Lion hunter
Re: too smokey? E15RERE
Did it clear up as you ran it or remain the same? Mine will smoke like that if I flood it but it usually clears up in a few minutes at idle.
Blake Hearn
I think this is most likely because of the sea foam. Especially if you mixed it pretty strong. Try running the gas out of it and running straight gas. It may clear up.
Rick.
Just to clarify, he means straight gas as in no seafoam. Oil is required. I'm just being cautious. Rick.
Lion hunter
NOT STRAIGHT GAS!!!! Mixed without sea foam.
rich79
i did mix it pretty stong. filled the gas tank with only gas/oil from 1/2 tank. taking the boat out tonight. this is the first time ive taken this motor out and didnt know if that was normal.
thanks for the help
lindy46
Seafoam will make it smoke like a house afire when used at high concentrations.:eek:
Rick.
Don't worry about that smoke. It's the seafoam doing it's job. I know it is a little embarrassing but your doing your cylinders and rings a great service. Rick.
kenmyfam
Should clear up after the seafoam has done it's job. If not post back.
