I found info on this a while back but can't find it again. I built a remote starter for testing but it doesn't crank the engine over as fast as the key will. I used 14 ga wire and aligator clips and a push button starter.
Is this how it should be built or should I get heavier wire?
I also got a marine load resistor and it didn't come with any instructions for use. Does anyone know how to use this for testing?
It might be a good sticky to put in the engine repair area for others to use as well. Thanks.
