Tools: Seal Puller and Installer
tallgrass55
I have a M8B Tohatsu and I am rebuilding the water pump and want to replace the oil seal directly below the waterpump.
Q.Where I can find an appropriately sized seal puller and seal installer?
Thanks
Brad
pvanv
Re: Tools: Seal Puller and Installer
That seal can be pulled with a generic small seal puller from an auto parts house. Or, if you're reasonably careful, you can use an appropriately-sized flat screwdriver (appropriately shaped to fit down into the cavity below the water pump) to carefully pry it out. You can install the new seal by driving it in with a hammer and a brass drift of appropriate size, of in a pinch, a socket from your set will do just fine.
tallgrass55
Thanks for advice! I finally pulled that ole prop seal out and put a new one.
Brad
