top impeller cover missing gasket?
mcva3
I figure I will start a new topic on this. Where i started it it had nothing to do with this.<br /><br /><br />I ordered a impeller rebuild kit from iboats part#18-3507. For a 64 mercury. 50hp<br />I noticed 2 things when i went to put it together. 1. The new impeller top is made of hard plastic and not metal like the old one, 2. The new impeller cover does not have a rubber seal in the whole where it slides down the shaft for a tight fit like the old one had. Is this suppost to be that way or did i not get something with the kit. Everything else semms to be ok. I would like to get this togehter and put it in the water. any help would be great. Thanks<br />Mike
Nos4r2
Re: top impeller cover missing gasket?
Contact iboats direct and ask them?
mcva3
I contacted sierra them selfs on the tech line. The new one just gets a rubber seal over the shaft on top of the case nothing else. Thanks<br />Mike
mcva3
It is all together!! I submerged it in the big trash can and fired it up. I had water coming out of the tell tale hole and everything seems fine. Had a little problem with the motor being stuck in forward gear but thanks to another post here on iboats i got it to work. Now time for the real test in the big tub. Thanks everyone who has helped<br />Mike
