Re: top rpm on 78 merc 1400 (140)
If 4300 is your WOT rpm, you are likely damaging the motor. You need a lower pitch or the motor is not running correctly.<br /><br />Check compression.<br />Prop this motor for 5700-6000 with a light load in the boat. Run 93 octane and set timing to 20* BTDC max.<br /><br />BTW- this motor is identical to the 77' 1500.
