TOP Speed Please Take a guess
Hi,<br />I have a boat just like this one in the picture. I have a 140 3.0 OMC with a prop that has a 16in pitch and a 13in diamiter. It is 16 feet long. I am not sure about the weight. The speedo is busted so I do not know what my top speed is. Can any one give me a guess of how fast it is. It seems really fast.<br /><br />Thanks,<br />Ben
Bob_VT
Re: TOP Speed Please Take a guess
Uhhhh what picture? Look your boat up on NADAGUIDES.Com and look for the retail price of used boats. That will give you the weight then used the theoretical formula posted here on the iboats site.<br /><br />OR<br /><br />Get a friend with a GPS to ride along and you will get an accurate speed.<br /><br />The speed formula uses weight hull type and horsepower... some require prop slip... GPS is the easiest.<br /><br />Bob
ZmOz
Just a rough guess, but you'd be lucky to hit 40. My 16' glastron with 150hp outboard does 50, and inboards are allways slower for a given HP.
It is a bayon custom that is why I can't look it up on NADAGUIDES.Com. I think I will order a new speedometer I just wanted a guess of how fast it is. <br />Thanks,<br />Ben
quantumleap
Borrow a hand-held GPS and you'll know exactly how fast.
I will buy a GPS to see how fast if some one can give me a guess so I know if it is even worth finding out lol.
cobra 3.0
My 1986 Peterborough bowrider with 3.0 140 hp Cobra goes 38 mph (gps) with a 19" pitch prop. If it's anything like the picture on ebay, that's a very flat, fast hull...probably around low 40 ish...but the 16" pitch is very short?!!! What does it rev at?
Ok I will get a GPS. It seems like I am flying. Also should I get a prop with more pitch?
ZmOz
I don't know what RPMs your motor is supposed to be at WOT, but probably more than 4100. That would mean you need a lower pitch prop...
Oh? I thought 4100 seemed high. I though like 4000 was probley righ. I will look it up.
I have really great acceleration and it levels out in like 3 sec. If you give it WOT. What do I need to do to learn what kind of prop is best?<br />Thanks,<br />Ben
ZmOz
First you need to find out what the WOT RPMs of the motor are supposed to be. If it's higher than what you're getting now, then you need a lower pitch. If it's lower (unlikely) then you need a higher pitch prop. If you're already in the right range, then do nothing. :)
quantumleap
Your motor has a recommended RPM range of 4200-4600 at WOT.
