Top speed problem
James matthews
Guys I have what I believe is a 1976. Its a 20hp mercury tiller handle. Motor runs flawlessly but will not go faster that 8mph. Its mounted on a 14ft fiberglass boat that's open hull and has a dry weight of about 400lbs
DblEagle
What style of hull is it? Deep v, flat bottom or catamaran like a Livingston?
Does the hull have a max HP capacity plate?
What is the max rating?
Add yourself, gas and the weight of the motor and your close to 700lbs total weight.
James matthews
I will check spark in next few days. I do have a spark tester. Its a like a semi tri hull but flat mostly
Chinewalker
Make sure the throttle linkage is giving you full advance on the carburetor. There are some plastic bits in there that can break...
