top speed ?
booger man
ok i got a 1997 sylvan 17 pro select with a 1978 merc 1150 il6 how fast should she run at wot ,is 45 to much to hope for?....Have a 17 and 19 pitch al props.....finally got her running good (fuel line problems )but the weather has been #4&*!$ , the rigs weight almost 25oo lbs loaded (fuel ,gear,batteries,and 25 hp kicker)...i'm pretty sure that with the 19pitch worn out prop rpms was 5200 to 5300, speedo is goffy and i always seem to foget the gps on unlimited hp lakes ,and 19 prop has been recently rebuilt havent tried the 17 yet...what do ya think :confused:
booger man
Re: top speed ?
well got to the lake and she ran great,40 mph with the 19 pitch,and 37 with the 17 pitch..,rpms were 5200 with 19 and 5350 with 17...,ps i forgot my gps AGAIN but i had a friend in another boat verify what my speedo was reading......any comments,ideas,advice
MurdockJr1
Re: top speed ?
I think you need to play with set-up on that boat RPM sounds low and that is hard on your motor.
walleyehed
Re: top speed ?
Yea...RPM is about 500-600 low. Can you raise the engine on the transom???
booger man
Re: top speed ?
i'm going out again this weekend and i will remember the gps and double check the rpm's due to the lousy weather we had (2-3ft wave action due to nasty winds)didn't get her trimmed out as much that day has me wondering if my results are correct,the ventalation plate is almost 1 inch above the keel,is that ok?
