pinto 21629
- Joined
- Aug 18, 2003
- 99
pinto21629 <br />Seaman <br />Member # 31253 <br /><br /> posted October 11, 2005 08:45 PM <br />--------------------------------------------------------------------------------<br />i have a 1962 17 foot aristo craft on a 1990 17foot high lander tilt tailer .it has like four 5" rollers and two short bunk boards the rollers are flat with a little ridge on the sides but i need to change them because it sat for about 11 years.there is a sunk in spot on one and a couple others dont turn well .the boat has a about a 1" or 1 1/2"keel on the bottom the guy i got it from did not have it set up for the boat he bought it like it was and took it home and just put the trailer on it.what would be the best rollers to put on it o i also have trouble loading it because the sides of the boat are right out even with fenders i dont think the flat rollers are right for it. i work at boaters world so i can get any rollers with a discount but cant deside what i need for it today i looked at a 8" roller with a grove in it for the keel but im still lost<br /><br />--------------------<br />pinto<br /><br />--------------------------------------------------------------------------------<br />Posts: 58 | From: maryland | Registered: Aug 2003 | IP: Logged | <br /> <br />Dave Abrahamson <br /><br />Senior Chief Petty Officer <br />Member # 22828 <br /><br /> posted October 12, 2005 09:35 AM <br />--------------------------------------------------------------------------------<br />Here's what I have. Work just fine<br /><br /> http://www.iboats.com/mall/index.cg...roller&**********=872018250&*******=227317604 <br /><br /> http://www.iboats.com/mall/index.cg...roller&**********=872018250&*******=227317604 <br /><br /> http://www.iboats.com/mall/index.cg...250&search_type=keyword&keywords=keel+rollers <br /><br />--------------------<br />I get by with a little help from my friends<br /><br />--------------------------------------------------------------------------------<br />Posts: 686 | From: Safety Harbor, Florida | Registered: May 2003 | IP: Logged | <br /> <br />pinto21629 <br />Seaman <br />Member # 31253 <br /><br /> posted October 13, 2005 05:39 PM <br />--------------------------------------------------------------------------------<br />i looked at the boat trailer today and i can only put 5"rollers on it the trailer frame hole are round not sloted so i can go with the same as i have they are spool rollers or i can get 5" ones that have a very small grove in the middle i looked at the 8"but the brackets will not fit my trailer will the small ones work i dont want to get them and the boat brake the roller because the grove to small???????????????????<br /><br />--------------------<br />pinto<br /><br />--------------------------------------------------------------------------------<br />Posts: 58 | From: maryland | Registered: Aug 2003 | IP: Logged | <br /> <br />Dave Abrahamson <br /><br />Senior Chief Petty Officer <br />Member # 22828 <br /><br /> posted October 14, 2005 02:45 PM <br />--------------------------------------------------------------------------------<br />If it had 5" ones on it before, it should be OK to replace with the same size.<br />How heavy is the boat? Fiberglass or aluminum?<br /><br />--------------------<br />I get by with a little help from my friends<br /><br />--------------------------------------------------------------------------------<br />Posts: 686 | From: Safety Harbor, Florida | Registered: May 2003 | IP: Logged | <br /> <br />pinto21629 <br />Seaman <br />Member # 31253 <br /><br /> posted October 14, 2005 04:16 PM <br />--------------------------------------------------------------------------------<br />it is fiberglass where i work has a 5"keel roller v roller but the groove in the middle is very small like 3/8" wide but i think that is for a deep v like a bay liner or a ski boat i was thinking about it because with the spool roller it all ways goes off center even when i tilt the trailer and winch it all the way up the trailer but if the spool rollers is all that will work thats what i will have to use the keel i was talking about comes off the bottom about 1"and its about 1"wide starts as the bow then turns into the keel on the bottom and ends about a 1'from the transom it is 17'fiberglass 1962 aristocraft<br /><br />--------------------<br />pinto
