topside on bottom?
Danimal1706
Will topside paint "easypoxy" accually, work well on the bottom of a old fiberglass stumpjumper, Im sure its not ideal but will I get 1 or 2 seasons on a trailered boat or will it just fall off? I should note that I plan to prepare surface as best I can sanding,primering,ect.. Also If I primer with spray can stuff, How will that work? <br /><br /> UPDATE I should tell you that there is plenty of ding and mounting holes repair going on. Now how about that primer? What do you recommend?
Re: topside on bottom?
On a Trailered Boat, It'll Last Forever.....<br /><br />It'll Stick Better, with a Well Sanded surface, Without Primer,<br />Than it will to Rattlecan Primer..........
LubeDude
I concure with Bondo. NO PRIMER if you are not sealing up a repair. 150-180 grit and paint. As they say, its all in the preporation!
