Torn carpet
MH9371B
Anyone know the best way to deal with torn carpet in my 1995 Sea Ray bowrider? It seems to spread like cancer!!
Re: Torn carpet
Sounds like it's Sun Rotted..........<br /><br />Might be Time to think about Replacing it.........
MH9371B
Re: Torn carpet
That can't be a very expensive procedure? Anyone ever have it done? Boat is 20'
Solittle
Re: Torn carpet
I'm not a fan of carpet in a boat due to mildew and if the carpet touches wood it can act as a sponge that can in turn lead to rot. Give some though to a textured or non skid paint.
bic-it
Re: Torn carpet
I just replaced the carpet in my 18' bass boat with a $100 kit. It went pretty well, but I recomend scrapping the glue that they give you and buy a gallon from home depot or lowes. It took I would say 15 man hours. I am happy with the results. I would post some pics, but I can't figure out how to.
MH9371B
Re: Torn carpet
bic -<br /><br />What kind of glue from Home Depot?
MH9371B
Re: Torn carpet
Anyone have any good tips or tricks to share when it comes to removing old carpet?
wvit100
Re: Torn carpet
I bought carpet for my boat from Home Depot for something like $2 per foot. I think the roll was 8' wide. Along with the glue it came to less that $50. I rough cut it in first, then took it out and put the glue down and finished it. It works out easier with two people.
bic-it
Re: Torn carpet
I bought a gallon of contact cement for about $12. It works a lot better than that stuff that the give you in a kit. You put it on each side, let it set for about 20 minutes and stick it. It will bond almost instantly. Removing the old stuff isn't fun. I bought a 3" wide razor blade and it worked OK. Took a little while, but get some friends to help and it isn't bad. I would recomend buying a lot of blades so that you can keep them sharp. I normal razor blade scraper works well in corners and on compartment lids. You could do what wvit did and buy your carpet from Home Depot. I would strongly recomend trying to keep large pieces intact so the you can just trace and cut.
Re: Torn carpet
Ayuh,........<br />Rip Out all that you can by hand........<br />Then a 4" angle Grinder, with a Wire Brush will remove All the remaining debris,+ Glue...........<br /><br />No, The Wire Brush will Not damage the Gelcoat..........
MH9371B
Re: Torn carpet
I finally got started with this. Will post before and after pictures when I'm done!<br /><br />Using Bondo's technique to remove the old glue and debris seems to be working well. I am just using my cordless drill with a wire brush bit instead of an angle grinder, though. I'm a little paranoid about the gelcoat though... I keep worrying if I'm pressing too hard.
MH9371B
Re: Torn carpet
Finally finished!! Wanted to post the before and after pictures and thank everyone for their advice. I bought the glue from Home Depot as suggested, and also used Bondo's advice for removing the old glue and debris.<br /><br /> http://pg.photos.yahoo.com/ph/mh9371b_2000/detail?.dir=/acd8&.dnm=bb7a.jpg <br /><br /> http://pg.photos.yahoo.com/ph/mh9371b_2000/detail?.dir=/acd8&.dnm=dcac.jpg <br /><br /> http://pg.photos.yahoo.com/ph/mh9371b_2000/detail?.dir=/acd8&.dnm=db50.jpg <br /><br /> http://pg.photos.yahoo.com/ph/mh9371b_2000/detail?.dir=/acd8&.dnm=f04a.jpg <br /><br /> http://pg.photos.yahoo.com/ph/mh9371b_2000/detail?.dir=/acd8&.dnm=60f1.jpg
lakelivin
Re: Torn carpet
looks good! how long did the total project take?
MH9371B
Re: Torn carpet
Total labor hours, I'd say 9-10. I stretched it over a 10 day period. The old carpet was completely rotten so I was not able to make a pattern from any of the old pieces. It came apart in shambles as I took it out. It was a lot of measure, cut, glue... I'm happy with the results though. After tearing the old carpet out I got estimates anywhere from $400 to $700 to install my new carpet, so I'm happy with the money I saved!
