Torque for prop shaft nut.
coalbucket
I have searched with no success. I purchased a 1988 88 Spl. a couple days ago and would like to run it in the morning. I would like to switch out the prop for a smaller pitch. The problem is my manual has not come in and I need to know the torque value for the nut on the prop shaft.
Oh by the way this is my first outboard, I have also been a I/O kind of guy.:^ But also bought my first fishing boat as well.
Thanks, Ken
AlanR
Re: Torque for prop shaft nut.
it dosnt really need to be "Torqued.. Just tight. Then you slide the cotter pin threw and your good to go.
Rancherlee
Usually tighten it up as tight as I can with my fingers and use a set of pliers to give it just enough twist to reach the next set of holes to allow the cotterpin to go in.
rdgallo
My 1994 150 Johnson calls for 70-80 ft. lbs.
imported_lorin
I've always wondered about this. Many outboard manuals list a high torque value for the prop nut. rdgallo, for example, says his 150 Johnson calls for 70-80 ft lbs. That's a lot of torque. But as some other posters have mentioned, just torquing a little more than finger tight seems to work fine, and doesn't result in any problems. This has been my experience also. So what's the need for a high torque value?
xtraham
I have read in the prop forum that it depends on the prop manufacture, some will rattle at low speeds if not properly torqued, I have seen recommedations up to 100 ft lbs for some... average is 55/65 ft lbs
