Torque, Lube and adhesive location
cudaguy71
1988 Alpha one #0B803692...
On page 3B-8 ? MR/ALPHA ONE/ALPHA ONE SS of Merc Manual #6 is the exploded view of the Gear housing... It has the torque reading and Lube and adhesive listings, however it does not show where to apply any of them... Does anyone know this?
Also Gasket #22 shows 2 water passages and the one I took out of mine only has 1...
Thank you for your time and help, Eddie
Re: Torque, Lube and adhesive location
Ayuh,... Just so I don't have to go dig up a manual,... Narrow your questions abit if ya could...
Like where is gasket #22,..??
The Lube goes in the bottom, til it runs out the top,...
Grease goes on any exposed splines,...
Glue is used on the bellows,...
Btw,... Welcome Aboard Eddie....
cudaguy71
Gasket #22 is at the base of the water pump... View shows the large center hole plus two other small holes, the gasket I pulled from mine has the large center hole but only one smaller hole...
Thank you...
