Torque spec. for 1955 seahorse 25hp
Woodstock60
My manual oly goes back to 1956, cant afford the earlier one yet so can anyone give me the following info on RDE-17.
1. torque value for piston bearing caps
2. torque value for head bolts
3. Crankcase cover has a spagetti seal, does it require the special sealant as well or no sealer just the pasta.
4. The new head gasket has no sealer inpregnated in it (most I have installed had a clear lacquer sealer already on them.) is the water jacket area ok with nothing?
Thanks to anyone who can help me.
F_R
Re: Torque spec. for 1955 seahorse 25hp
1. Depends on the bolt size. 1/4"-28 are 180-186 IN/Lbs, 9/32"-28 are 216-222 IN/Lbs
2. 220-240 IN/Lbs
3. Scotchgrip #847 (formerly Sealer 1000)
4. Some have different opinions. I use OMC Gasket Sealant on the uncoated ones.
Note the torques are in inch pounds. A foot pound wrench is not accurate enough.
