Torque specs info
trucker28
I have a 1956 7.5 HP johnson I need the torque specs on the head bolts I think they call it head bolts the part i need to bolt back on is were the spark plugs screw into
Willyclay
Re: Torque specs info
The specs for your motor are 60-84Inch-Pounds BUT the cylinder head bolts must be tightened in the proper sequence. If you need a manual, try the link below:
http://forums.iboats.com/showthread.php?t=393281
Drill down to: Small Engines, Marine/Boat Motors, Evinrude/Johnson and then select the second file from the top; Outboard 10HP (1955-1963) which also contains 7.5HP data.
Good luck with that great old motor!
EDIT: I just went through that manual and it does not contain the sequence. Will keep looking. Meanwhile, maybe another forum member can provide that info.
trucker28
thanks for the spec 60- 84 seems like lot bt ok and the sequence i have a rough idea on that thanks again
schematic
Trucker28
The spec he gave is in inch pounds......Divide by 12 to get foot pounds...
Willyclay
Roger that, INCH-POUNDS! Here's the sequence from an OMC manual for my 6HP:
9 10
5 6
1 2
4 3
8 7
EDIT: The system took out my spacing so you could compare them with the cylinder head. FYI, No. 9&10 are the top two, 1&2 middle, 7&8 bottom and 3&4/5&6 widest outside bolts.
OMC recommends you re-torque all bolts after running the motor at normal operating temperature AND after the motor has cooled. Hope this helps.
trucker28
9 10
5 6
1 2
4 3
8 7
good info thank you
