Re: Torque wrenches:Inch pounds or foot pounds
I think there's really 2 issues here, one is what scale ie inch/lb vs ft/lb vs newton/mtrs and the second is working range. You should always try to go with a tool working in the midrange of it's capacity vs one working at either extreme of it's working range. The same logic applies to what drive to use , ie. 3/4 inch drive to torque wheel bolts, 3/8 for plugs and 1/4 for small screws and bolts so, just as you should have 1/4, 3/8, 1/2, 3/4 and maybe even inch drive sockets, you really should have several q wrenches to cover several working ranges
