I will assume 2 cylinder head your torquing? The easyest way is to tell you is draw the head with the 10 bolts the looking from the back top rt the numbers going down is 8 4 1 5 9 then top left is 7 3 2 6 10 If you then look its starts in the middle rt and goes across then up across then down so on. If its a 3 cylinder you can do the same starting at the middle most and following same patterm.
Thanks for the info Stinky.<br />Actually it is a 3 cyl motor with 18 head bolts. <br />top row has 2, 2nd row 2, 3rd row 4, 4th row 2 5th row 4 6th row 2 and 7th row 2. I am assuming torque would be around 20 pounds?<br /><br />Thanks
