total loss of power
pigster30
have a 1990 115 inline 6 mercury outboard. all last year it ran great. i took it out today and it ran like a champ, after about 25 minutes it started to lose power. at idle it does fine, but if you take it up over 1500 rpms it starts to bog and will not go over 2200 rpms. i didn't add fuel stabilizer or drain the carbs last year (DA move i realize).
Mercury140-I6
Re: total loss of power
I don't mean to sound like an a$$, but if you have an inline 6 115, it can't be any newer than 1988. As for your problem with it, others with more information about this motor will chime in soon.<br /><br />Giving the serial # might be helpfull though.<br /><br />Hope you can get that beast of yours running right soon.<br /><br />Craig
Perfidiajoe
Sounds like you need to clean & rebuild the carbs., then power tune the engine. Run some fresh gas through it with carbon guard, or sea foam, or some such product & go from there. Good luck Joe
mattttt25
i would get new gas going to the engine, and then decarb it. see if that works first.
pigster30
the new gas worked, now i need to get a new gasket and i'll be drowning worms again.<br />Craig, it's a191556.<br /><br />thanks for the help.
