jodymartin
- Joined
- Sep 5, 2010
- 55
Boat&motor- 1986 21' bayliner capri-aq225e #cu56837.....
new carb, dist, dist cap, plugs, wires, rotor.... timing set at 8 degree btdc at 600rpm....
engine idles great at 700rpms.... put the boat in the water under a load and it runs fine up to 3000rpms then the secondaries open and it boggs down.... if i pump the throttle it will catch up and run fine at 4200rpms for as long as you want it to but if i slow down same issue....
now with someone else driving and they go to wot.... if i turn the dizzy while the engine is bogging out it will run great all the way from 1300 to 4200 rpms... but it has a loud tapping noise sounds like the lifters and idles rough....
any help will be great
