Re: Tow Vehicle. What Gear Should I be in.
As for the "auto" feature on your front hubs, I'll bet you a box of beer that that is sort of an "auto 4 X 4 " feature. By that I mean, when you are driving down the highway or side street or what ever, and all of a sudden it snows 5 inches and you need four wheel drive, with out stopping or putting the truck in neutral, you can keep driving and turn the 4x4 switch to 4hi, this will engage the transfer case and simultaneously and automatically lock up your front hubs. When you no longer need 4 wheel drive, with out stopping or putting the truck in neutral, keep driving and put the 4x4 switch back in 2hi. After a few miles the hubs will unlock by themselves, or you have to stop and back up 10 feet, either one. As stated before the "manual" mode on the hub is for when you are or will be in a real predicament and do not want the hubs to unlock. Again, back in Auto mode, , once you flip the switch on the dash to 4hi you will need at least 10 feet in either direction to engage the front hubs.
So you could use the auto function on the boat ramp, just flip the switch on the dash to 4hi as you are backing down the ramp, not at the bottom when you are at a dead stop.
4lo will also work with the auto mode, the only difference is that when you go into and out of 4 lo you will need to put the transmission in neutral.
Turning corners in four wheel drive on wet or even dry pavement wont hurt anything. Yes the driveline will bind the wheel in opposite corners will scratch/slip, but driving 10 feet like that wont do anything. As stated before, if you did that for a month straight, yeah there's going to be some badness.
Oh, just be advised that when the auto lock hubs on Fords get a bunch of miles on them, say over 90-100,000 they may not work any more (the auto mode) they weren't really known for their hi mileage ability.
You'll know if it's not working when you drive down the road in 2hi and all of a sudden you get a big clunk from up front that makes your coffee shake.
Good Luck.
Oh, maybe you want to read the manual, , , , sorry I just had to.
