Renegadesurvivor
- Joined
- Apr 22, 2009
- 10
Hey Peoples!!
I bet you all thought i forgot!! Nope just took me awhile to get this done.
So it works now!! A side from the carb..there was also the fact that the idle throttle was not moving as much. And how we had started it was priming the bulb till fuel came out of the carb, spaying mixed fuel into the carb as cranking and then having the idle throttle moved as far as it would go..it worked and started to pull it's own fuel and stayed running.
So now I have another problem. No water came out of the pee'r. I only let it run about 30 seconds at a time (did it twice) because of this. I wasn't wanting to blow the engine i just got running over a cooling problem.
