Tower of Power
gunterm
So I've narrowed down my idling problems to the tower's various adjustments. Idle is fairly smooth, but occasionally it "jumps", and I'm trying to figure that out. The Clymer's manual is basically useless as it doesn't have a picture that shows what these things are and how to adjust. I was hoping someone (Frank? :)) can help me identify the stuff in the picture below and how to adjust:
gustafsonerik
Re: Tower of Power
thats a good question i know the top is timing and the middle thing that looks like a tie rod is used to make sure wot and idling........this is what i did i set the timing at idle tdc the slow moved the top over until it hit tdc then i set the idle using the "tie rod"
john from md
Re: Tower of Power
1. this is the timing adjustment for the trigger. It is only adjusted after the carb sync adjusments are made.
2. this is the carb/timing link. You need to adjust the carbs first, then the trottle cable, then adjust this. It must be done by the book.
3. this is the mixture adjustment screw. Start from 1 1/8 turns out and adjust per the book.
4. I did not see a circle around the idle speed screw which is located at the middle of the vertical timing bar. You should adjust this in the water for a RPM of 750 after everything else is done.
Don't forget to give your engine a good decarb before making the final mixture and speed adjustments.
John
gunterm
Re: Tower of Power
John
That's odd because the clymer's says #3 is the idle screw, that explains why messing with it causes things to run strange. Where is the vertical timing bar? Is that the tower?
I've noticed lately it's not going into forward "soon" enough and it grinds a while before setting into gear, is there an adjustment for that?
john from md
Re: Tower of Power
The timing 'tower' is the vertical shaft with the plastic connector with the screw that adjusts the timing.
Item 3 is the mixture screw, each carb has one. Adjusting it makes the mixture lean or rich.
The adjustment for the shift lever is done with the shift cable but you mark the shift rod to make the adjusments. There is a step by step process listed in the manual.
John
gunterm
Re: Tower of Power
John
Ah cool, thanks! Since a tach doesn't exist that works on this motor I just do the idle speed by ear.
john from md
Re: Tower of Power
Buy an inductive tach used for cars on ebay. You can get one for $20, make sure it has a switch for 2 and 4 cycle engines. Suntune is one make, Craftsman another. You only need to use it when you set up the engine.
Don't set the idle by ear. If it is not correct, you will get excessive wear in the shift dogs. They are not cheap or easy to change. Get the tach.
John
