Re: towing a sailboat
Well after reading what you will be towing I would have some reservations mainly given the length of time involved in that tow. I am guessing based on time that you mentione the marina you are going to is around 25 + miles away which is a bit of a haul and could really pose some problems if you are not properly prepared. Even though you are driving a BW, if your boat becomes disabled or the weather picks up and you are no longer able to manage, you AND your buddy are going to be in a really bad place. I am thinking given the distance you might call Sea-Tow or one of those guys and see what the tow cost is. Again I am not sure why you are having to tow him that distance, the nice part about a sailboat (especially a 30 footer) is that it should have either an aux outboard or an inboard diesel. So if you cant sail it, then motor it or vise versa. If the boat is that disabled where you cannot sail or motor it then I would be looking at calling in the pros, they have the tools and back up to get you through any situation. Also if he is able to motor or sail then go along as a support vessel, but pulling that entire distance is a stretch. Take if from a guy who has used a BW for pulling a boat and had it swamped by a wave, it makes for a really bad day.
