Towing a tuber
stuball56
I have this 14' fishing boat (see picture) with 25hp, is it safe to pull a tube with this boat? What problems should I expect or look out for, or is this just not a good idea?<br /><br />
studlymandingo
Re: Towing a tuber
You'll probably have a hard time getting on plane, but once up, you should be good. You may have to take some slack in the rope and get a running start on the tube in order to plane out. Smart tabs will help, a whale tale might even help that setup.
stuball56
Re: Towing a tuber
I just put this 25 on the boat, had a 15hp Johnson, what a difference!! With me alone it jumps up on plane instantly, the 15hp wouldnt plane with me(230#) and a buddy of the same weight. I am hoping this 25 will help with that too. Thanks for the advice.
Texasmark
Re: Towing a tuber
You have a nice flat stern area on your boat which says a lot for getting out of the hole.<br /><br />I have found that the large tractor tubes (14.5x24) to name one, works very well. The larger tubes provide better buoyancy and helps to keep the rider out of the water.....which is your worst enemy....drag.<br /><br />Also I prefer lots of air; firm tube. Rides better, comes up a lot better, and reduces drag cause you can keep all but the rider's toes out of the water.<br /><br />Have fun and good luck,<br /><br />Mark
Texasmark
Re: Towing a tuber
One more tidbit.<br /><br />Got a "Tractor Supply Co." store near you? They are on www and have a store locator. They stock all sorts of tubes.....unless you are in a farming area and have a tire store handy that caters to them (farmers)....may have some old ones lying around.<br /><br />Mark
stuball56
Re: Towing a tuber
OK thanks, how would I hook up to the tube? Just tie a rope around it? We have a tractor supply store just up the road here in Coopersville, MI, farm country for sure.
Texasmark
Re: Towing a tuber
Just wrap the line around it tight enough to where it deforms the tube and go. With a good tight tube you'll never wear a hole in the tube. <br /><br />Then on the boat end I was going to say tie it onto the stern cleats but I don't see any on your boat in the picture.<br /><br />Usually there is a thru transom cleat on either side of the transom used to attach the rear of the boat to the trailer while trailering. These are your tie points.<br /><br />You would do best if you obtained a pair, look at other boats to see where they are installed and install them.....thru the transom.<br /><br />Then for best luck make a lanyard with a roller/ float hootus (boat dealer/ski shop/wally world maybe has them....just a roller ok if you use poly line) that allows the tow line to revolve about the rear of the boat.....from side to side as the tube moves from side to side, or in a turn, it forces the pull to the inside of the turn which helps you control things. <br /><br />Make it long enough so that it's about a foot behind the rear of the engine when you stand behind the boat and pull on it. That will give you adequate clearance from the engine yet not be too far out back.<br /><br />Using this rolling connection, rather than a firm mount to a fixed cleat allows better control of the boat with the tube (or skis) in different angles from the rear of the boat. BTDT.<br /><br />Best to use a poly.... line as it floats......keeps the line out of your prop. At least 3/8" in diameter, 1/2 would be better and expect to change it out every couple of years.<br /><br />2 Cautions:<br /><br />Turn the engine OFF anytime you are loading and unloading tubers till they swim a safe distance away. A prop can make some real nasty cuts on a human and could be fatal. It only takes a second to have an accident.<br /><br />Do not use deck cleats for what you want to do as they are made for mooring, not pulling. They will probably pull out if you try pulling the tube with them......get the hookup I mentioned.<br /><br />Good luck,<br /><br />Have fun.<br /><br />Mark
Texasmark
Re: Towing a tuber
On the size of the tube, wife and I had 4 kids and lived near the water. We did our thing a lot. The larger tubes aired up good and firm just allaround gave a better performance and less drag on the person and the boat. You can start out with an auto or truck, but won't be long and you'll be off to TSC for a big tube.<br /><br />Mark
MrBigStuff
Re: Towing a tuber
I tried an old inner tube once. Some guy was selling them for this purpose. Left black marks on everyones suits and skin. Not to mention the large, metal stem sticking out. After someone got cut on the thing, it went in the trash and I bought a plastic tube meant for towing. For the cost difference, I wouldn't mess with an old inner tube. Just my double lincolns...
jtexas
Re: Towing a tuber
Originally posted by Texasmark:<br /> Then on the boat end I was going to say tie it onto the stern cleats but I don't see any on your boat in the picture.<br />
It's got carry handles on the stern - those'll work just fine.<br /><br />Lot of good advice here. A real enthusiast might even think about getting a lower pitched prop just for tubing.<br /><br />I got one of those hang-over-the-side ladders - it's pretty convenient for this purpose. Before that, anybody too heavy to be lifted in had to climb in over the outboard. Using the antiventilation plate as a step. Best have the engine turned off for that operation. ;) <br /><br />You might want to think about getting some tie-down straps for trailering - keep the boat & trailer together in case of an accident - and it might surprise you how high that boat can bounce if you drop a wheel off a curb - probably not likely to clear that side bunk - just a thought.
LubeDude
Re: Towing a tuber
Now with all this said, I dont know if I agree that you can safly pull a tube with your 14' boat. :eek: <br /><br />I have in the past towed regular inner tubes and the ski tubes made for water sports. I can tell you that pulling an inner tube will take a lot more effort as they have no bottom and tend to pull a lot harder. Im not sure that you could do it with others in the boat and you have to have at least one more person as a spotter. Even with my last 15' Bass boat with a 75 HP, when the rope would get in the water and the tue was out to one side, it would try and pull the rear of the boat off to the side. I think that under the same situation with your light boat, that it would have spun you out and that could be dangerous.<br /><br />I think you shouldnt try it. :eek:
rogerwa
Re: Towing a tuber
It also depends on the size of the rider in the tube.. A smaller person will have less effect than a bigger one.. At my lake there are teenagers that ski behind a 14' with 25hp. all day long. It can be done.
cobra 3.0
Re: Towing a tuber
Aluminum boats have runners/ribs. They will not slip like your bass boat does. But as with everything new you try, go slower first and turn less tight to see how your boat reacts. And for everyone's sake please have everyone wear their life jackets in the boat and on the tube!
paulie0735
Re: Towing a tuber
Oh god, is it any wonder so many people get hurt in our sport. Tractor tubes are for keeping tractor tires full of air. They are not for keeping your loved ones safe while having fun on the end of a tow line connected to your boat. Do it properly, purchase a 'designed for the purpose' ski tube and tow line. They have handles to hold on to, they have inbuilt protection for the air ring and have a bottom to keep them on top of the water and the occupant inside and relatively safe. I'm also with bassin' fever re your boats suitability, but with the 'correct' gear and a firm hold of your common sense you should be ok.
