Re: Towing - (another boat)
OK, I'll chime in. I'm in the Coast Guard Auxiliary, and proper towing is one of the "skills" we're expected to learn, practice and do well. So far this year, I've towed 5 boats, and it's only the middle of June...<br /> The following is sort of like asking someone what time it is, then getting an explanation of how clocks work....
<br /><br />First, you shouldn't tow faster than the displacement speed of the towed boat. On a 20' boat, that's about 5-6 mph. Pulling a boat until it's up on plane is a good way to court damage to either/both boats. Displacement tows won't cause any stress on the towing boat's engine, either.<br /><br />2nd: That was good advice about attaching the tow line to the bow eye of the towed boat. Too many boats have improper backing for their cleats. My boat has good backing on the stern cleats, so I use them; some CGAux boats have samson cleats for that purpose. A ski/board boat almost always has strong cleats/posts for towing. Never seen tying to the motor; think that would be difficult for most boats.<br /><br />3rd: One ideal set-up for a stern tow would be to have a heavy poly-pro bridal (extending back from both stern cleats) on the towing boat (so it would float out of way of the propeller), then heavy braided nylon for the tow line. But unless you tow often, you won't have that set-up, so use whatever is handy. Yeah, the advantage of poly-pro is that it floats, but it's also the weakest line on your boat, and since it doesn't stretch, there is the potential for damage by slamming and jerking, especially in heavier water. We use heavy nylon which does stretch; most of the time, we're towing boats well under 60', so line breaking isn't an issue. <br />4: a side tow is the easiest for control, as well bringing the disabled boat into the dock. But unless you've practiced...and have lots of fenders...it's an easy way to damage boats. If you're not practiced, as Ross said, use the stern tow, cast loose near the dock, and then nudge/raft them in.<br /><br />Make sure everyone on the towed boat has their life jackets on, and don't be shy about telling your towee what you're doing and why. As previously stated, use lots of line and an extra, if possible.<br /><br />And this is one of those times when the courts have upheld the Good Samaritan laws. Don't test them by screwing up big time, but even if you're not confident of your abilities, you won't be punished by attempting to help someone out in the drink when they're truly in trouble.
