Re: Towing Multiple Wakeboarders?
I disagree- towing two skiers, boarders, whatever at a time is fine as long as you do it safely and correctly. I've been skiing and wakeboarding dual/with others for a years now and as long as you follow some safety rules, everyone can have a fun time. The taller skier will be in the back, the shorter up front (closer to the boat). Ensure one rope is much shorter, but not too short, than the other and they can tie into the same eye. When both skiers are ready, start a slow drag until slack is out of both ropes, then hit it. When the skiers are up, each person will need to communicate and time their crosses with the rear skier paying close attention and lifting the rope at the appropriate time. I always found it easier to be in the center of the wake when the other skier crossed. If one skier drops, both drop. Be safe, have fun.
I weigh 210 and I've skied with a range of other sized people behind a 4.3 liter which popped us up with no issue whatsoever. It might be a little struggle with the 3.0 but still not bad with wakeboards which require far less power than pulling up dual skiers.
