Towing with cover on?
If under 10 miles, sure, or stay under 50mph, over that no way
Alumarine
If you do watch out for snaps undoing and the canvas flapping.
Flapping canvas will mess things up.
89retta
I had the same cover on my old boat. Towed it with the cover on for 1100 kms and speeds between 100-120kms per hour. Had no problems.
Stingrayaxe
I think it really depends on the cover. I wouldn't travel far or fast with the cover that is on the boat in the picture. On the other hand if you had a full towing rated mooring cover then there is not a problem. They are designed to be towed with. Even the semi-custom covers that tie down to the trailer with straps work well for towing.
Silvertip
Preventing air from getting under the cover is the key as to whether or not you tow with the cover on. A properly fitted and secured cover should not be a problem (at least it wasn't an issue for me). However the boat pictured will have a huge low pressure area behind the helm. That cover would likely balloon or pop loose at freeway speeds.
JASinIL2006
I found towing to be much less of a hassle if I just leave any covers off the boat. Making sure the cover is properly secured, that it's not beating itself to death in the wind, that straps haven't loosened/come free, or that the cover is getting ready to fly off the boat add too stress to boat towing for me. And that's with a towing cover!
I'd be worried that a nice camper top like that would quickly get ruined at highway speeds. If you're talking about a 30 mph drive home from a nearby ramp, that's another story. No way I'd put that camper top through a long trip at hi speed.
gm280
I hear both sides of the towing with cover on stories. I've hear some that have no problems while others talk about the vibration/flapping movement marring the hull to the point that they can't get the marred marks off anymore. So I personally wouldn't, but that is just my opinion.
Rix86
I doubt I can replace that cover easily. But there's not a lot of room in the boat to store the thing either.
But it would be decent protection from rain while out n about. So....torn here.
Maclin
Just thinking that what you showed us is not what I would call a boat cover. That is full camping enclosure, not meant to go faster that just light cruising speeds on the water. A boat cover meant to tow looks much different, has straps all the way around, things like that. I would not tow with what you showed much over 30mph, and then only for short distances, especially if it is aged at all.
JASinIL2006
Easy way to figure out it it's worth it to tow with that thing or not: take it to a canvas shop and ask what it would cost to make one just like that. Compare the quote from the canvas shop to what a true trailering cover would cost and determine if the difference is worth the risk.
jkust
I bet it has a tag on it warning you not to tow over a certain speed. My boats all have had the canvas package and part of that is a two piece mooring cover that I towed with regularly and they each had that warning tag with a 30mph limit but those covers were very taught and the tow vehicle really made a dead zone of not much wind action for the bow portion of the cover. Your navy/convertable top just sticks up above the windshield much further than a mooring cover which is flat.
