Why store it in the upright position? I leave the 90HP up, and the 25HP down. The 25 is a 4-stroke, the 90 is a 2-stroke. Is it ok to leave it up if you use it often?
Some outboards are great at spitting fuel out the carbs if they are stored tilted up. Always down for storage at least...
Gee, I have never believed that the power trim of a motor cannot support the weight of a motor while being trailered. That simply makes no sense as the power trim can hold the motor in any trim position all day at full throttle. Ditto for the transom strangth. If a bump in the road causes enough stress to crack your transom, be glad you found it while trailering, as full throttle while underway would put lots more strain on it.
Anyway, the answer to the OP's question is: If you have PTT trim the motor up enough to clear any road obstacles, and you are good to go. Locking it all the way up is fine, but unnecessary, and can cause the motor to bounce more.....If no PTT, locking it up or using a transom saver make make sense.
Tow whichever way gives you adequate skeg clearance. The issue is storing it when you get home. If it's a carburetored engine, store it in the upright (running) position. Never store it in the tilted up position.
