I have a j130 vxsss and noticed a gray residual like oil and water on one of my top plugs. Engine is not down on power but not ideling well when in gear at 700 rpm. I am suspecting a head gasket issue. Will be doing a compression test tomorrow, 2 years ago they were all 125psi after cranking each for equal time. If I do not see a difference in this cylinder versus others should I still suspect gasket? Do these gaskets require a special sealer when new ones are istalled? All the bolts are numbered is this the torque sequence? Thanks in advance for replies
One other point after running on muffs I removed this sparkplug and one below and noticed what appeared to be steam coming from offending cylinder.
