edsylvianoe
- Joined
- Mar 22, 2003
- 1
I have a 1990 Tracker 40 hp Johnson motor, Model #TJ40ELESR, Serial # G 02531655 that has not been used for approximately 2 years. When it was fired up this year it would not do over 1200 RPMs. I have tried everything I can think of to correct the problem with negative results. I do not get any warning alarms and the engine does not seem to be overheated and the problem is constant. It will start and run at Idle but the minute you increase the throttle it will start missing and bog down. I have spark at both Cylinders, have changed the Plugs, pulled the carbs and cleaned them. Tried different gas, changed the gas tank checked for fuel leaks. The problem does not change if I squeeze the gas tank primer ball. Any help would be appricieated.<br /><br />Everette
