TRACKER PONTOON
ceedy
HOW MUCH AIR PRESSURE SHOULD THERE BE IN THE PONTOONS ON MY TRACKER PONTOON ????
SpinnerBait_Nut
Re: TRACKER PONTOON
ceedy, welcome to iboats.<br />I do not think there is any pressure in them. The air valves you see are most likely there to check for leaks.<br />If any pressure, it would be slight because of problems with the welds. Too much pressure can cause the welds to come loose.
Poppie Bear
Re: TRACKER PONTOON
I just purchased a 24 Party Fishing Barge, and according to the info, they hold 10 lbs
jebeebe
Re: TRACKER PONTOON
10 would be max (cold) rember when the sun hits them they will spike. If they don't leak you don't need any except for dent issues.
