rookie456
- Joined
- Aug 25, 2011
- 81
I bought a used 17 foot blue fin with a continental trailer back in July. I pull the trailer with a Pontiac Montana. It trailers nice, doesn't wag. A few weeks ago I noticed the tread on the tire was worn on the inside of the tire, kind of in a saw tooth pattern. After investigating more, I noticed that both tires have extreme negative camber, which explains the tire wear, I also noticed that the axle looked bent in the middle, which would cause the negative camber. There is a mark on the top of the axle, right in the middle, it looks like maybe the bottom of the boat hit the top of the axle and bent it downward. Right now, with the axle bent, I have about a 2" clearance from the axle to the bottom of the boat. If I put a new axle on the trailer I think it would be hitting the bottom of the boat. The only thing I can think of that would cause this would be worn out leaf springs. They don't seem to be worn out, but I dont know a whole lot about boat trailers. I know I need new tires, and an axle.
