Trailer axle hub help needed.
NxtGoRnd
I have a Texas Royal Manufacturing boat trailer from 1972 that seems to be running an uncommon spindle and have not been able to source a hub. The inner bearing is LM67048 which is 1 1/4 I.D. with a LM67010 outer race. The outer bearing is a LM11949 3/4 I.D. with a LM119104 race. The bearings are available to be had but have had no luck in finding a hub. Really do not want to replace spindle or axle unless there is no choice. Thanks for any help, Tony
dingbat
NxtGoRnd
Thanks, I did find the agricultural hub online at one of the other trailer parts not sure if the bore length is the same. Even if bore length works I will have one oddball rim unless I buy 4 and change all the hubs but that is a possibility. Thanks again for the help and heads up on that hub. Tony
