Trailer bearings
syost
Its a 1971 Coast. I had a bearing go bad. Pulled them off and took them in to Napa. I found out that the Bearings were true ball bearings. The part numbers that Napa gave me is BCA B01 $30.00 AND B02 $70.00. $100.00 TOTAL EACH WHEEL. Looking for advice on if anyone has a good idea were I can get them cheaper. Or any other ideas. Any help would be great.<br /><br />Thanks<br />syost
Boatist
Re: Trailer bearings
Syost<br />I and sure can get whole hub cheaper than that but may just be able to replace with the new tapered bearing kit. You could check at IBOAT or try Champion trailers.<br /><br /> http://www.championtrailers.com/
H*ll, You can buy a Whole New Axle, With Hubs for Less Money....
