haulnazz15
- Joined
- Mar 9, 2009
- 3,720
I picked up a 2001 Trail Master 22' trailer with a boat I needed a few scrap parts for. I bought it for $375 with a running V8 engine (I needed the lower unit). So, since I'm scrapping the boat, I think I'll swap this trailer out for the older one I already have on my boat.
Here's the issue: the newer trailer has hydraulic drum surge brakes on both axles, but they don't appear to work, and the actuator doesn't provide any resistance at all when you push on the tongue. In fact, the trailer brake actuator just slams back/forward about an inch or so when towing, making starts/stops a bit jarring. So the question is, do you go about trying to find the culprit (the reservoir is full of brake fluid) or do you just bite the bullet and install a completely new setup? If I get the new setup, I'd go with hydraulic surge disc brakes to simplify everything and I don't want to bother mounting an electric brake controller in my truck.
Side note: my runabout weighs between 3-4K lbs, so total weight with trailer is around 5Klbs. Probably not necessary to have brakes on both axles, but I dunno. We've been running our old trailer without trailer brakes for 20 years, so aside from the legality standpoint, we'd be benefited by trailer brakes of any sort.
