Trailer Bunks
lugnutzz75
i was wondering if i put the teflon/plastic skids on my bunks would i need carpet on them??
Re: Trailer Bunks
Other than for Looks,...... You don't Need Anything covering the Bunks..........<br /><br />Wood works Fine all by itself.......<br /><br />I'm Sure that Wood, with plastic strips will Also work......
tashasdaddy
Re: Trailer Bunks
i use roller bunks, make loading so much easier, just be sure to hook the bow before you pull the trailer out of the water.
Texasmark
Re: Trailer Bunks
I just installed the plastic over existing carpet. Had the bunks been in need of replacement, I would have used treated wood and no carpet then install the plastic runners.<br /><br />Really made a difference on my boat and it's light. Can imagine what they would do for a heavy one that you couldn't float the boat on or off.<br /><br />Mark
poolshark38759
Re: Trailer Bunks
my prob is with the ramps at the lakes i use.. they are either really flat or really steep.. so i was wnating them to make launching easier.. on the shallow ramps i have to get the bronco wheels in the water to the trailer half under water. and the steeper ramps the trailer goes too deep to get the on or off..
tashasdaddy
Re: Trailer Bunks
that's why i like the rolle bunks, the boat rolls on and off,, you don't drag it.
Major Woods
Re: Trailer Bunks
I have a 26'WA with bunk slicks (no carpet). These things are so slippery that a one hand push is all that's required to get it off the trailer and this is on a shallow angle launch. <br /><br />On steep angle launches we have to let out the winch line. We can not disconect cable from the boat until it is in the water, to much tension on the hook as the boat it wants to slide off the bunks. A little to slippery at times :D <br /><br />
kywildcat
Re: Trailer Bunks
Where would I look at this plastic covering on line. I have a little trouble at the ramps that I have to use also. Thanks
