Trailer doesn't have safety chain
kaulbr
I have a new-to-me 2015 19' Four Winns with the OEM trailer. It has a crank winch strap but no additional safety chain. All other trailers I've ever seen always had a chain as well in case the strap were to break. Is that not always needed? Makes me nervous.
GA_Boater
Add one. You won't know you need a safety chain until it's too late.
mike_i
Ensign
You really don't need a safety chain but it's very cheap insurance in case the strap breaks. There's really no reason to not have one, here's a picture of my chain.
Bt Doctur
you need help too.
3/8ths link at the minimum and a screw shackel not a hook
Bt Doctur
It should make you nervous, get a chain on there. Aside from losing the boat or causing an accident you will also be cited for "Failure to secure load"
briangcc
It probably came from the factory with a 2" strap in front that secured to the winch post - mine did. I'd definitely look at getting something there to act as a fail safe for the winch strap.
My current boat has a steel cable (plastic coated) with an S hook and retaining spring. Depending on your setup this *might* be another option for you.
MTboatguy
My winch post has a slot to put the chain in, works quite well, I have a screw shackle and just put the chain in the slot and twist.
kaulbr
Thanks all for the input. Do you think this triangle at the base of the trailer is where the strap/chain is meant to attach? Also, any recommendations as to what to buy?
MTboatguy
Might be, but I know I have seen a lot of trailers over the years that was not even designed to take a safety chain, in those cases you just have to figure it out.
roscoe
You can use a transom strap if you have an extra one.
On my boat, I installed an extra bow eye.
Both hooks would not fit in the bow eye, so added the second one.
superbenk
My Four Winns trailer came with a short ratcheting bow strap. You can find them online for about $20-30. I like that better than the chain because I can cinch it down. I hook to the small hole in the flat plate that supports the winch tower. I think that’s a stronger location than the triangular piece you pointed out (my trailer has that too).
Definitely don’t run without one. An accident will cost you far more than the $20-30 for a strap.
Cortes100
Yes that triangle is exactly what you use. A simple ratchet strap from the triangle to the bow eye. Your trailer would have came like that from factory but obviously the seller didn't give you that. Mine is exactly the same. All units in the showroom were like this.
kaulbr
Nice, thanks for the info!
