Re: Trailer gurus... I need some input on leaf springs
Well to me it dose look a bit closer to the end of the spring pocket than I would like but it also depends on if you can adjust the centering trunnion a bit as well as the back axle and hanger. You have to have room for movement and from what I can see of the wear pattern it looks like its doing OK. It looks like a duel axle and that is on the front axle, if you have a set of holes to move it it, personally I would. It looks like the front axle and you may be able to move the front axle a bit foward, a lot less work. Cant really tell if you have adjustment holes.
