Trailer Light Wiring Question 4 Pole Conn.
Has any one wired trailer lights on a 2004 Ford Taurus? Could you give me the wire colors and where you tie-in. I have paid a garage to to this already but I am not sure if they did it correctly. My clearance lights do work but do not light the led on my tester. Also if I turn on the brakes and the clearance lights at the same time the actual passenger side light does not light up at all. otherwise the lights do work if tested one function at a time. Any help is appreciated.
George
Re: Trailer Light Wiring Question 4 Pole Conn.
Ayuh,... You need to establish a Solid Ground,...It sounds like it's only grounded through the hitch...
Jumper from frame to frame,+ I bet they'll work Right...
