Trailer Lights
AirForceOne
I'm having trouble with my rear trailer lights. I have a 2007 Toyota Tacoma truck, with a 6 pin hook up with a 4 pin adapter.
The brake and turn signals work fine with the truck head lights off, but when I turn them on, the right rear brake light on the trailer stays on and the turn signal barely works? The left light works fine? Any Ideas?:confused:
EddiePetty
Re: Trailer Lights
...triple check your ground connection from the P/U, through six-pin, into the adaptor and finally at the trailer. Insufficient ground will cause all kinds of weird lighting.
Bifflefan
Re: Trailer Lights
Possible its a corroded socket or a bulb with a crossed filament.
Im thinking its in that one light somewhere. Test the wires at that light individually, Im betting the wiring is good and its in the light.
