JoshKeller84
- Joined
- Jul 2, 2010
- 220
3/8" flat bar, bent by hand in a vise with some heat added. 2 x 4, carpet, couple of u bolts and bolts for the 2 x 4. drill the bolt head side of the 2 x 4 3/8" and pounded the head in it so it wouldnt come out and scratch boat. total cost was about $30
detailed instructions: i cut 3/8" flat bar into 17" bars. put the u bolts on the trailer frame and measured the bolt width, then marked it onto them metal and drilled two 3/8" holes for each bar. i bolted them on upside down to bend the first bend. after bending, and flipping the bar around, i measured where i would like the second bend to begin, marked it, then measured how far i would need the top of the metal to move to get the desired angle of the 2 x 4. put in vice at the bend mark, and heated just enough to be able to bend it. most of the tops needed moved approx 1 inch to get the desired 2 x 4 angle.
the ends are fairly open carpet wise, and the bottom of the board is open as well to help facilitate the wood drying fast.
im 6'4" and 220 lbs, and i can hang/lean on the 2 x 4 and it flexes about an inch then immediately spings back to that position, so i think they will work great.
