Hey guys, I just found out my hull is basically stuffed and not worth fixing and was wanting to replace it with a new one.
The boat is 16ft and I was wanting to get one at 17ft if possible. The trailer looks adjustable on all the rollers/as well as the winch frame. Is it bad if the hull hangs over the last roller? If I adjusted it out as long as possible a 17ft would probably hang over the last roller by around 10cm/6inches or so. Could I get away with this?
Cheers.
Cheers.
