Trailer spring bushing question
dgopetactical
Hi,
I have a 87 load-rite tandem. I have noisy spings and I have come to the conclusion that my sping bushings need attention. I have NEVER worked on leaf springs before and my question is, what is the proper way to jack a loaded trailer and support it properly (tention on the springs)to do a bushing job one axel at a time? I dont want to go removing bolts and have the spring tention do bad things. Any help would be great.
Thanks,
Denny
Re: Trailer spring bushing question
Ayuh,....
You can jack under the frame, rather than the axle... Then Block it up...
You want NO tension on the axle/ springs you're workin' on....
