Re: Trailer tire question
Absolutely -- replace the tire. When you go shopping, you will need the size shown on the sidewall. You will also need to know whether you need one with five holes or four. You are probably going to end up buying a tire and a wheel, and it might not be such a bad idea to just replace them both now, particularly if you do a fair amount of distance trailering. Unless you have air tools, by the way, the old nuts can be a bugger to get off. You might want to have your local garage mount the new tires for you. Figure on spending $50 or $60 each for the tires, and add in a tip for the guy who puts them on for you.
